A Genetic Algorithm Compared with a Gradient-Based Method for the Solution of an Active-Control Model Problem
Abstract : In this study, a linear active-control model problem is employed to conduct a preliminary performance comparison between a genetic algorithm and a classical optimization method based on the evaluation of a gradient of functional. For this purpose, we consider a system modeled by the heat equation in one space dimension controled by a source term. The cost functional is a quadratic form of the distance between the final state and a prescribed function augmented of a penalty involving the control quadratically. The problem is first solved by a direct identification of the «optimal-control law» from the solution of a Riccati system. A simple genetic algorithm is implemented afterwards and compared.
Type de document :
Rapport
RR-2948, INRIA. 1996
Liste complète des métadonnées
Littérature citée [1 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00073751
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 13:41:07
Dernière modification le : samedi 27 janvier 2018 - 01:31:29
Document(s) archivé(s) le : dimanche 4 avril 2010 - 23:57:00
Fichiers
  • HAL Id : inria-00073751, version 1
Collections
Citation
Nathalie Marco, Cyril Godart, Jean-Antoine Desideri, Bertrand Mantel, Jacques Périaux. A Genetic Algorithm Compared with a Gradient-Based Method for the Solution of an Active-Control Model Problem. RR-2948, INRIA. 1996. 〈inria-00073751〉
Métriques
Consultations de la notice
205
Téléchargements de fichiers
224
