A Stochastic Minimax Optimal Control Problem on Markov Chains with Infinite Horizon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
We consider here a stochastic discrete minimax optimal control problem defined on a finite state Markov chain in the case of infinite horizon. We prove the existence of an optimal control in terms of a generalized feedback policies. We characterize the optimal cost function and we present iterative methods to compute it numerically.
RR-2946.pdf (234.95 Ko) Télécharger le fichier
inria-00073753 , version 1 (24-05-2006)
  • HAL Id : inria-00073753 , version 1
Silvia C. Di Marco, Roberto L.V. González. A Stochastic Minimax Optimal Control Problem on Markov Chains with Infinite Horizon. [Research Report] RR-2946, INRIA. 1996. ⟨inria-00073753⟩
52 Consultations
94 Téléchargements
