Circuit-Switched Gossiping in the 3-Dimensional Torus Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
Stéphane Pérennes
  • Fonction : Auteur
  • PersonId : 942945
In this paper we describe, in the case of short messages, an efficient gossiping algorithm for 3-dimensional torus networks (wrap-around or toroidal meshes) that uses synchronous circuit-switched routing. The algorithm is based on a recursive decomposition of a torus. The algorithm requires an optimal number of rounds and a quasi-optimal number of intermediate switch settings to gossip in an $7^i \times 7^i \times 7^i$ torus.
Autre [cs.OH]
RR-2930.pdf (198.56 Ko) Télécharger le fichier
inria-00073769 , version 1 (24-05-2006)
  • HAL Id : inria-00073769 , version 1
Olivier Delmas, Stéphane Pérennes. Circuit-Switched Gossiping in the 3-Dimensional Torus Networks. RR-2930, INRIA. 1996. ⟨inria-00073769⟩
76 Consultations
204 Téléchargements
