Gossiping in Torus with Wormhole-Like Routing, Proceedings of the " ¡ IEEE Symposium on Parallel and Distributed Processing, 1995. ,
An overview of wormhole routing. I3S -CNRS URA 1376 -Manuscript, 1996. ,
Performance analysis of k-ary n-cube interconnection networks, IEEE Transactions on Computers, vol.39, issue.6, pp.39775-785, 1990. ,
DOI : 10.1109/12.53599
The torus routing chip, Distributed Computing, vol.28, issue.1, pp.187-196, 1986. ,
DOI : 10.1007/BF01660031
Deadlock-Free Message Routing in Multiprocessor Interconnection Networks, IEEE Transactions on Computers, vol.36, issue.5, pp.547-553, 1987. ,
DOI : 10.1109/TC.1987.1676939
URL : http://authors.library.caltech.edu/26907/1/5206-TR-86.pdf
Diffusion en mode commutation de circuits Edition spéciale, présentation des activités du GDR-PRC Parallélisme, RenPar'8, pp.53-56, 1996. ,
A necessary and sufficient condition for deadlock-free adaptive routing in wormhole networks, IEEE Transactions on Parallel and Distributed Systems, vol.6, issue.10, 1995. ,
A theory of deadlock-free adaptive multicast routing in wormhole networks, IEEE Transactions on Parallel and Distributed Systems, vol.6, issue.9, 1995. ,
Communications intensives dans les architectures a ` mémoire distribuée et algorithmes parallèles pour la recherche de racines de polynômes, 1990. ,
Methods and problems of communication in usual networks, Discrete Applied Mathematics, vol.53, issue.1-3, pp.79-133, 1994. ,
DOI : 10.1016/0166-218X(94)90180-5
A survey of gossiping and broadcasting in communication networks, Networks, vol.3, issue.4, pp.319-349, 1986. ,
DOI : 10.1002/net.3230180406
On forwarding indices of networks, Discrete Applied Mathematics, vol.23, issue.2, pp.103-123, 1989. ,
DOI : 10.1016/0166-218X(89)90022-X
Optimal broadcast in all-port wormhole-routed hypercube, IEEE Transactions on Parallel and Distributed Systems, vol.6, issue.2, pp.200-204, 1995. ,
Gossiping in vertex-disjoint paths mode in interconnection networks, Proc. 19th Int. Workshop on Graph-Theoretic Concepts in Computer Science (WG'93). LNCS. to appear ,
DOI : 10.1007/3-540-57899-4_60
Gossiping in vertex-disjoint paths mode in d-dimensional grids and planar graphs, Proc. First Annual European Symposium on Algorithms (ESA'93), pp.200-211, 1993. ,
DOI : 10.1007/3-540-57273-2_56
Optimal algorithms for broadcast and gossip in the edge-disjoint paths modes, Proc. 4th Scandinavian Workshop on Algorithm Theory (SWAT'94). LNCS. to appear ,
Optimum broadcasting and personalized communication in hypercubes, IEEE Transactions on Computers, vol.38, issue.9, pp.1249-1268, 1989. ,
DOI : 10.1109/12.29465
Virtual cut-through: a new computer communication switching technique, Computers Networks, vol.3, pp.267-286, 1979. ,
DOI : 10.1016/0376-5075(79)90032-1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.460.3486
The relationship between gossiping in vertex-disjoint paths mode and bisection width, Proc. 19th Int. Symp. on Mathematical Foundations of Computer Science, 1994. ,
DOI : 10.1007/3-540-58338-6_94
Adaptive Multicast Wormhole Routing in 2D Mesh Multicomputers, Journal of Parallel and Distributed Computing, vol.28, issue.1, pp.19-31, 1995. ,
DOI : 10.1006/jpdc.1995.1086
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.54.8988
An adaptive and fault tolerant wormhole routing strategy for k-ary n-cubes, IEEE Transactions on Computers, vol.40, issue.1, pp.2-12, 1991. ,
DOI : 10.1109/12.67315
A survey of collective communication in wormhole-routed massively parallel computers, 1994. ,
Collective communication trees in wormholerouted massively parallel computers, 1995. ,
A survey of wormhole routing techniques in direct networks, Computer, vol.26, issue.2, pp.62-76, 1993. ,
DOI : 10.1109/2.191995
The iPSC/2 direct-connect technology, Proceedings of 3rd Conference on Hypercube Concurrent Computers and Applications, pp.51-60, 1988. ,
DOI : 10.1145/62297.62305
Circuit-switched broadcasting in torus networks, IEEE Transactions on Parallel and Distributed Systems, vol.7, issue.3, pp.246-255, 1996. ,
DOI : 10.1109/71.491578
Efficient Multicast in All-Port Wormhole-Routed Hypercubes, Journal of Parallel and Distributed Computing, vol.31, issue.2, pp.126-140, 1995. ,
DOI : 10.1006/jpdc.1995.1151
