Abstract : In this paper we consider a deterministic impulsive control problem. We discretize the Hamilton-Jacobi-Bellman equation satisfied by the optimal cost function and we obtain discrete solutions of the problem. We give an explicit rate of convergence of the approximate solutions to the solution of the original problem. We consider the optimal switching problem as a special case of impulsive control problem and we apply the same structure of discretization to obtain also a rate of convergence in this case. We present a numerical example.
