Euler Sums and Contour Integral Representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Bruno Salvy
This paper develops an approach to the evaluation of Euler sums involving harmonic numbers either linearly or nonlinearly. We give explicit formul{æ} for certain classes of Euler sums in terms of values of the Riemann zeta function at positive integers. The approach is based on simple contour integral representations and residue computations.
Autre [cs.OH]
RR-2917.pdf (385.16 Ko) Télécharger le fichier
inria-00073780 , version 1 (24-05-2006)
  • HAL Id : inria-00073780 , version 1
Philippe Flajolet, Bruno Salvy. Euler Sums and Contour Integral Representations. [Research Report] RR-2917, INRIA. 1996. ⟨inria-00073780⟩
97 Consultations
570 Téléchargements
