A Criterion for Uniqueness of a Critical Point in $H_2$ Rational Approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
This paper presents a criterion for uniqueness of a critical point in $H_{2,\RR}$ rational approximation of type $(m,n)$, with $m\geq n-1$. This criterion is differential topologic in nature, and turns out to be connected with corona equations and classical interpolation theory. We illustrate its use on three examples, namely best approximation of fixed type on small circles, a de Montessus de Ballore type theorem, and diagonal approximation to the exponential function of large degree.
RR-2869.pdf (429.58 Ko) Télécharger le fichier
inria-00073822 , version 1 (24-05-2006)
  • HAL Id : inria-00073822 , version 1
Laurent Baratchart, Edward B. Saff, Franck Wielonsky. A Criterion for Uniqueness of a Critical Point in $H_2$ Rational Approximation. RR-2869, INRIA. 1996. ⟨inria-00073822⟩
61 Consultations
65 Téléchargements
