Parallel Operators
Jean-Marc Jézéquel 1 Jean-Lin Pacherie 1
1 PAMPA - Models and Tools for Programming Distributed Parallel Architectures
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : Encapsulating parallelism and synchronization code within object-oriented software components is a promising avenue towards mastering the complexity of the distributed memory supercomputer programming. However, in trying to give application programmers benefit of supercomputer power, the library designer generally resorts to low level parallel constructs, a time consuming and error prone process. To solve this problem we introduce a new abstraction called Parallel Operators. A Parallel Operator exists simultaneously on all processors involved in a distributed computation: it acts as a single entity capable of processing shared or distributed data in parallel. In this paper we reify this concept in our Eiffel Parallel Execution Environment (EPEE) context, and we show that it is both natural and efficient to express computations over large shared or distributed data structures using Parallel Operators. We illustrate our approach with an Parallel Operator based solution for the well-known N-body problem.
Type de document :
Rapport
[Research Report] RR-2862, INRIA. 1996
Liste complète des métadonnées
https://hal.inria.fr/inria-00073829
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 13:50:37
Dernière modification le : mercredi 16 mai 2018 - 11:23:04
Document(s) archivé(s) le : dimanche 4 avril 2010 - 21:43:17
Fichiers
  • HAL Id : inria-00073829, version 1
Citation
Jean-Marc Jézéquel, Jean-Lin Pacherie. Parallel Operators. [Research Report] RR-2862, INRIA. 1996. 〈inria-00073829〉
Métriques
Consultations de la notice
255
Téléchargements de fichiers
184
