Stochastic Dynamics: Simulating the Effects of Turbulence on Flexible Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
This paper addresses the problem of realistically simulating the motion of tree-branches subjected to turbulence. Since the resulting motion is random in nature, we model it as a stochastic process. We synthesize this process directly by filtering a white noise in the Fourier domain. The filter is constructed by performing a modal analysis of the tree. We use a sophisticated numerical technique which is able to compute the first few significant modes of large trees. The main advantage of our technique over previous methods is that we are able to compute complicated motions without the need to integrate dynamical equations over time. Consequently, tree-motions can be viewed and manipulated in real-time by a user. Our technique can further be extended to other flexible structures such as two-dimensional plates.
Autre [cs.OH]
RR-2847.pdf (364.23 Ko) Télécharger le fichier
inria-00073844 , version 1 (24-05-2006)
  • HAL Id : inria-00073844 , version 1
Jos Stam. Stochastic Dynamics: Simulating the Effects of Turbulence on Flexible Structures. [Research Report] RR-2847, INRIA. 1996. ⟨inria-00073844⟩
108 Consultations
618 Téléchargements
