Detecting Diamond Necklaces in Labeled Dags (A Problem from Distributed Debugging) - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1996
The problem tackled in this paper originates from the debugging of distributed applications. Execution of such an application can be modeled as a partially ordered set of process states. The debugging of control flows (sequences of process states) of these executions is based on the satisfaction of predicates by process states. A process state that satisfies a predicate inherits its label. It follows that, in this context, a distributed execution is a labeled directed acyclic graph (dag for short). Debug or determine if control flows of a distributed execution satisfies some property amounts to test if the labeled dag includes some pattern defined on predicate labels. This paper first introduces a general pattern (called diamond necklace) which includes classical patterns encountered in distributed debugging. Then an efficient polynomial time algorithm detecting such patterns in a labeled dag is presented. To be easily adapted to an on-the-fly detection of the pattern in distributed executions, the algorithm visits the nodes of the graph according to a topological sort strategy.
RR-2838.pdf (300.37 Ko) Télécharger le fichier
Dates and versions
inria-00073852 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00073852 , version 1
Cite
Michel Hurfin, Michel Raynal. Detecting Diamond Necklaces in Labeled Dags (A Problem from Distributed Debugging). [Research Report] RR-2838, INRIA. 1996. ⟨inria-00073852⟩
103 View
95 Download
Share
