Dynamic Load Balancing in Hierarchical Parallel Database Systems
Abstract : We consider the execution of multi-join queries in a hierarchical parallel system, i.e., a shared-nothing system whose nodes are shared-memory multiprocessors. In this context, load balancing must be addressed at two levels, locally among the processors of each shared-memory node and globally among all nodes. In this paper, we propose a dynamic execution model that maximizes local load balancing within shared-memory nodes and minimizes the need for load sharing across nodes. This is obtained by allowing each processor to execute any operator that can be processed locally, thereby taking full advantage of inter- and intra-operator parallelism. We conducted a performance evaluation using an implementation on a 72-processo- r KSR1 computer. The experiments with many queries and large relations show very good speedup results, even with highly skewed data. We show that, in shared-memory, our execution model performs as well as a dedicated model and can scale up very well to deal with multiple nodes.
keyword : PARALLEL DATABASES
Type de document :
Rapport
[Research Report] RR-2815, INRIA. 1996
Liste complète des métadonnées
Littérature citée [36 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00073877
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 13:58:38
Dernière modification le : mercredi 21 novembre 2018 - 19:26:10
Document(s) archivé(s) le : lundi 5 avril 2010 - 00:00:45
Fichiers
  • HAL Id : inria-00073877, version 1
Collections
Citation
Luc Bouganim, Daniela Florescu, Patrick Valduriez. Dynamic Load Balancing in Hierarchical Parallel Database Systems. [Research Report] RR-2815, INRIA. 1996. 〈inria-00073877〉
Métriques
Consultations de la notice
730
Téléchargements de fichiers
623
