Non-commutative Elimination in Ore Algebras Proves Multivariate Identities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Frédéric Chyzak
Bruno Salvy
Many identities involving special functions can be proved using the theory of D-finite or holonomic sequences and functions. This theory applies in particular to numerous combinatorial identities. This work presents a theoretical and algorithmic approach to the multivariate case, together with an implementation.
Autre [cs.OH]
RR-2799.pdf (427.52 Ko) Télécharger le fichier
inria-00073891 , version 1 (24-05-2006)
  • HAL Id : inria-00073891 , version 1
Frédéric Chyzak, Bruno Salvy. Non-commutative Elimination in Ore Algebras Proves Multivariate Identities. [Research Report] RR-2799, INRIA. 1996. ⟨inria-00073891⟩
62 Consultations
339 Téléchargements
