Abstract : In the paper the support of a Radon measure is selected in an optimal way. The solution of the second order elliptic equation depends on the mesure via the mixed type boundary conditions. The existence of a solution for a class of domain optimization problems is shown. The relaxed formulation of the optimization problems is proposed. The first order necessary optimality conditions are derived.
https://hal.inria.fr/inria-00073903 Contributor : Rapport de Recherche InriaConnect in order to contact the contributor Submitted on : Wednesday, May 24, 2006 - 2:02:45 PM Last modification on : Friday, February 4, 2022 - 3:22:48 AM Long-term archiving on: : Monday, April 5, 2010 - 12:01:21 AM
Antoine Henrot, Werner Horn, Jan Sokolowski. Domain Optimization Problem for Stationary Heat Equation. [Research Report] RR-2788, INRIA. 1996, pp.26. ⟨inria-00073903⟩
