HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Optimal Loop Parallelization under Register Constraints
Christine Eisenbeis 1 Antoine Sawaya 1
1 A3 - Advanced analysis to code optimization
UP11 - Université Paris-Sud - Paris 11, Inria Saclay - Ile de France
Abstract : This report deals with the interaction between instruction scheduling and register allocation, in the case of straight line code and in the case of loops. This problem is at the heart of code optimization in microprocessors with instruction-level parallelism. Usual solutions use heuristics based on a decoupled approach. We propose here a formulation by linear integer programming, that allows dependence, resource and register constraints to be integrated in the same framework . By varying the parameters, all kinds of optimization problems can be solved exactly (maximization of the throughput, minimization of the number of registers). We report on examples of computation timings that turn out to be prohibitive in some specific cases, but tractable on average.
Document type :
Reports
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/inria-00073911
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:03:20 PM
Last modification on : Friday, January 21, 2022 - 4:04:22 AM
Long-term archiving on: : Thursday, March 24, 2011 - 1:19:10 PM
Identifiers
  • HAL Id : inria-00073911, version 1
Citation
Christine Eisenbeis, Antoine Sawaya. Optimal Loop Parallelization under Register Constraints. [Research Report] RR-2781, INRIA. 1996. ⟨inria-00073911⟩
Share
Metrics
Record views
200
Files downloads
85
