Concurrent AVL Revisited: Self-Balancing Distributed Search Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
We address the concurrent insertion and deletion of keys in binary almost balanced search trees (AVL trees). We show that this problem can be studied through the self-reorganization of distributed systems of processes controlled by local evolution rules in the line of the approach of Dijkstra and Scholten. This yields a simple and abstract presentation of the insertion and deletion mechanisms. In particular, we show that our approach encapsulates a number of previous attempts described in the literature. They can in fact be seen as ad hoc specializations of the nondeterministic evolution rules. This solves in a very general setting an old question raised by H.T. Kung and P.L. Lehman: where should rotations take place to rebalance arbitrary trees?
RR-2761.pdf (373.99 Ko) Télécharger le fichier
inria-00073931 , version 1 (24-05-2006)
  • HAL Id : inria-00073931 , version 1
Luc Bougé, Joachim Gabarrò, Xavier Messeguer. Concurrent AVL Revisited: Self-Balancing Distributed Search Trees. [Research Report] RR-2761, INRIA. 1995. ⟨inria-00073931⟩
142 Consultations
446 Téléchargements
