Reports
Adaptive Parallel Query Execution in DBS3
Abstract : The gains of parallel query execution can be limited because of high start-up time, interference between execution entities, and poor load balancing. In this paper, we present a solution which reduces these limitations in DBS3, a shared- memory parallel database system. This solution combines static data partitioni- ng (by hashing the relations across the disks) and dynamic processor allocation (using shared- memory) to adapt to the execution context. It makes DBS3 almost insensi tive to data skew and allows decoupling the degree of parallelism from the degree of data partitioning. To address the problem of load balancing in the presence of data skew, we analyze three important factors that influence the behavior of our parallel execution model: skew factor, degree of parallelism and degree of partitioning- . We report on experiments varying these three parameters with the DBS3 prototype on a 72-node KSR1 multiprocessor. The results demonstrate high performance gains, even with highly skewed data.
Document type :
Reports
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/inria-00073943
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:08:17 PM
Last modification on : Friday, February 4, 2022 - 3:07:27 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:46:52 PM
Identifiers
  • HAL Id : inria-00073943, version 1
Collections
Citation
Luc Bouganim, Benont Dageville, Patrick Valduriez. Adaptive Parallel Query Execution in DBS3. [Research Report] RR-2749, INRIA. 1995. ⟨inria-00073943⟩
Share
Metrics
Record views
40
Files downloads
147
