HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Bounds on Finite Horizon QoS Metrics with Application to Call Admission
Abstract : In this paper we are concerned with a discrete time, single server system in which packets arrive from a finite population of sources. Under the assumption that arrivals from each source are modulated by a Markov process, we consider the following metrics {\em (i)} the fraction of an interval that the queue length exceeds a certain value, and {\em (ii)} the fraction of a group of packets from a single source that arrive to find the queue length above a certain value. For both metrics we derive upper and lower bounds on the probabilities that they exceed a threshold. These are important measures because they reflect more accurately the behavior perceived by applications such as networked audio and video. An application of these results to call admission is also given.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00073958
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:10:24 PM
Last modification on : Friday, February 4, 2022 - 3:17:13 AM
Long-term archiving on: : Thursday, March 24, 2011 - 1:29:38 PM
Identifiers
  • HAL Id : inria-00073958, version 1
Collections
Citation
Zhen Liu, Philippe Nain, Don Towsley. Bounds on Finite Horizon QoS Metrics with Application to Call Admission. RR-2735, INRIA. 1995. ⟨inria-00073958⟩
Share
Metrics
Record views
70
Files downloads
85
