Subpixel Image Registration by Estimating the Polyphase Decomposition of the Cross Power Spectrum
Abstract : A method of registering images at subpixel accuracy has been propos ed, which does not resort to interpolation. The method is based on the phase co rrelation method and is remarkably robust to correlated noise and uniform varia tions of luminance. We have shown that the cross power spectrum of two images, containing subpixel shifts, is a polyphase decomposition of a Dirac delta funct ion. By estimating the sum of polyphase components one can then determine subpi xel shifts along each axis.
Type de document :
Rapport
RR-2707, INRIA. 1995
Liste complète des métadonnées
https://hal.inria.fr/inria-00073983
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 14:14:14
Dernière modification le : samedi 27 janvier 2018 - 01:31:27
Document(s) archivé(s) le : jeudi 24 mars 2011 - 13:37:05
Fichiers
  • HAL Id : inria-00073983, version 1
Collections
Citation
Hassan Shekarforoush, Marc Berthod, Josiane Zerubia. Subpixel Image Registration by Estimating the Polyphase Decomposition of the Cross Power Spectrum. RR-2707, INRIA. 1995. 〈inria-00073983〉
Métriques
Consultations de la notice
137
Téléchargements de fichiers
272
