HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Boundary Conditions and Layer technique for the Simulation of Electromagnetic Waves above a Lossy Medium
Francis Collino 1
Abstract : Two inovative techniques for the simulation of the effect of a lossy dielectric half-space are derived and analysed. The first is an adapted impedance surface condition imposed at the interface to replace the dielectric medium. This condition, when coupled with Maxwell's equations yields a stable system which can be written in a variational form. It allows us to take into acccount both the polarization and the angle of incidence of the out-going waves. The second technique is a generalization of the Bérenger perfectly matched layers: the dielectric is now replaced by a short length layer in which the waves are governed by a modification of Maxwell's equations. For this model, the two reflection coefficients are the same as for the true dielectric while the damping inside the layer is enforced.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00073992
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:15:32 PM
Last modification on : Friday, February 4, 2022 - 3:08:36 AM
Long-term archiving on: : Thursday, March 24, 2011 - 1:39:24 PM
Identifiers
  • HAL Id : inria-00073992, version 1
Collections
Citation
Francis Collino. Boundary Conditions and Layer technique for the Simulation of Electromagnetic Waves above a Lossy Medium. [Research Report] RR-2698, INRIA. 1995. ⟨inria-00073992⟩
Share
Metrics
Record views
57
Files downloads
62
