HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Non-rigid Motion without Relying on Local Features: a Surface Model Applied to Vortex Tracking
Abstract : Motion study in computer vision highly depends on the type of imagery and on the kind of the studied objects. A popular approach of non-rigid motion supposes that the objects are continuously and locally deformed. Local features, such as curvature extrema, are then often used. However, these features can not always be accurately computed, and motion may involve large deformation of the object between two consecutive temporal occurrences. In these cases, there is a real need for an approach that does not rely on local features. That study of motion requires additional information. We introduce a geometrical evolution model that enables to generate a surface interpolating the two successive contours of the object during its temporal evolution. This geometrical model may be viewed as a simplification of the true physical model of motion. This approach is particulary well suited to remote sensed data: structures of interest do not have a well defined shape, and the temporal resolution may be poor, involving large deformation. We successfully apply our model to vortex tracking on sea color images and on meteorologic images.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074007
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:17:03 PM
Last modification on : Friday, February 4, 2022 - 3:08:10 AM
Long-term archiving on: : Monday, April 5, 2010 - 12:03:22 AM
Identifiers
  • HAL Id : inria-00074007, version 1
Collections
Citation
Jean-Paul Berroir, Isabelle Herlin, Isaac Cohen. Non-rigid Motion without Relying on Local Features: a Surface Model Applied to Vortex Tracking. [Research Report] RR-2684, INRIA. 1995. ⟨inria-00074007⟩
Share
Metrics
Record views
43
Files downloads
112
