New Progress in Anisotropic Grid Adaptation for Inviscid and Viscous Flows Simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Two new ideas for anisotropic adaptation of unstructured triangular grids are presented with particular emphasis to fluid flows computations. The first concept enables a suitable extension of our mesh adaptation to the case of systems of PDE like Navier-Stokes equations and the second makes possible a correct boundary layer computation which was until now one of the major weakness of anisotropic adaptations in CFD.
Autre [cs.OH]
RR-2671.pdf (12.22 Mo) Télécharger le fichier
inria-00074019 , version 1 (24-05-2006)
  • HAL Id : inria-00074019 , version 1
Manolo Castro-Diaz, Frédéric Hecht, Bijan Mohammadi. New Progress in Anisotropic Grid Adaptation for Inviscid and Viscous Flows Simulations. [Research Report] RR-2671, INRIA. 1995. ⟨inria-00074019⟩
146 Consultations
176 Téléchargements
