A Posteriori Error Estimators for Linearized Semiconductor Equations with Mixed Finite Elements Approach in $H(\div) \times L^2$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
In the framework of Mixed Finite Element Methods, the mathematical analysis of an error indicator, which relies on the residual of a linearized Drift-Diffusion model of the transport equation for electrons in heterojunction semiconductor devices using Fermi-Dirac statistic, is presented. Just now, no numerical experiences have been carried out in order to prove the efficiency of the proposed isotropic estimator. However, from its numerical interpretation, it appears that they are coherent and well indicate the boundary layer and abrupt hetrerojunction problems.
RR-2666.pdf (339.04 Ko) Télécharger le fichier
inria-00074024 , version 1 (24-05-2006)
  • HAL Id : inria-00074024 , version 1
Abderrazzak El Boukili, Manolo Castro-Diaz. A Posteriori Error Estimators for Linearized Semiconductor Equations with Mixed Finite Elements Approach in $H(\div) \times L^2$. [Research Report] RR-2666, INRIA. 1995. ⟨inria-00074024⟩
103 Consultations
226 Téléchargements
