Regular Solutions of Second-Order Stationary Hamilton-Jacobi Equations - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1995
We study a second-order stationary Hamilton-Jacobi equation in infinite dimension. This equation is nonlinear and convex with respect to the first-ord- er term. We use properties of a the transition semigroup associated to the linear equation to write the Hamilton-Jacobi equation in integral form and we prove that this solution is the pointwise limit of a uniformly bounded sequence of classical solutions of approximating problems. Finally, the solution is the value function of the associated optimal stochastic control problem. Some examples are given.
RR-2649.pdf (343.08 Ko) Télécharger le fichier
Dates and versions
inria-00074041 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00074041 , version 1
Cite
Fausto Gozzi, Elisabeth Rouy. Regular Solutions of Second-Order Stationary Hamilton-Jacobi Equations. [Research Report] RR-2649, INRIA. 1995, pp.33. ⟨inria-00074041⟩
50 View
183 Download
Share
