Regular Solutions of Second-Order Stationary Hamilton-Jacobi Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
We study a second-order stationary Hamilton-Jacobi equation in infinite dimension. This equation is nonlinear and convex with respect to the first-ord- er term. We use properties of a the transition semigroup associated to the linear equation to write the Hamilton-Jacobi equation in integral form and we prove that this solution is the pointwise limit of a uniformly bounded sequence of classical solutions of approximating problems. Finally, the solution is the value function of the associated optimal stochastic control problem. Some examples are given.
RR-2649.pdf (343.08 Ko) Télécharger le fichier
inria-00074041 , version 1 (24-05-2006)
  • HAL Id : inria-00074041 , version 1
Fausto Gozzi, Elisabeth Rouy. Regular Solutions of Second-Order Stationary Hamilton-Jacobi Equations. [Research Report] RR-2649, INRIA. 1995, pp.33. ⟨inria-00074041⟩
52 Consultations
195 Téléchargements
