On Integer Chebyshev Polynomials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Laurent Habsieger
  • Fonction : Auteur
Bruno Salvy
We are concerned with the problem of minimizing the supremum norm on [0,1] of a nonzero polynomial of degree at most $n$ with integer coefficients. We use the structure of such polynomials to derive an efficient algorithm for computing them. We give a table of these polynomials for degree up to 75 and use a value from this table to answer an open problem and improve a lower bound from~[3]
Autre [cs.OH]
RR-2648.pdf (243.55 Ko) Télécharger le fichier
inria-00074042 , version 1 (24-05-2006)
  • HAL Id : inria-00074042 , version 1
Laurent Habsieger, Bruno Salvy. On Integer Chebyshev Polynomials. [Research Report] RR-2648, INRIA. 1995. ⟨inria-00074042⟩
38 Consultations
182 Téléchargements
