Transient queue length and busy period of the BMAP/PH/1 queue - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Bruno Sericola
We derive in this paper the transient queue length and the busy period distributions in the single server queue with phase-type (PH) services times and a batch Markovian arrival process (BMAP). These distributions are obtained by the uniformization technique which gives simple recurrence relations. The main advantage of this technique is that it leads to stable algorithms for which the precision of the result can be given in advance.
Autre [cs.OH]
RR-2646.pdf (221.72 Ko) Télécharger le fichier
inria-00074044 , version 1 (24-05-2006)
  • HAL Id : inria-00074044 , version 1
Bruno Sericola. Transient queue length and busy period of the BMAP/PH/1 queue. [Research Report] RR-2646, INRIA. 1995. ⟨inria-00074044⟩
85 Consultations
58 Téléchargements
