Robust Matching by Partial Correlation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Visual correspondence problem (matching), %including stereo matching and motion matching, is an major issue in vision. Matching can be divided in {\it feature-based} and {\it area-based} matching. In area-based matching, correlation is a common tool for the visual correspondence problem. But most classical correlation methods fail near the disparity discontinuity, which occurs at the boundaries of objects. In this report, we propose a {\it partial correlation} technique for solving this problem. We use a robust statistics tool to find the {\it good part} to be considered for applying correlation, We have compared our method with the standard and non standard techniques. Experimental results validate the approach.
Autre [cs.OH]
RR-2643.pdf (344.6 Ko) Télécharger le fichier
inria-00074047 , version 1 (24-05-2006)
  • HAL Id : inria-00074047 , version 1
Zhong-Dan Lan, Roger Mohr. Robust Matching by Partial Correlation. [Research Report] RR-2643, INRIA. 1995. ⟨inria-00074047⟩
181 Consultations
263 Téléchargements
