HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Hierarchical Production Planning for General Jobs Shops : Part 1 : Modeling
Abstract : The study is divided into two parts. In part 1, we provide an extensive bibliographical study on the subject and introduce a two-level hierarchical production planning model. The whole model is composed of the low level model, the high level model, and the links between both. These models are supposed to be known. We provide a mathematical formulation of the production planning problem and an iterative algorithm to solve it. In the second part of the study, we will provide several numerical examples, including an industrial application. We will also provide a comparison of the hierarchical approach and the monolithic approach in terms of efficiency, memory requirement and computational complexity.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074054
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:23:57 PM
Last modification on : Friday, February 4, 2022 - 3:23:42 AM
Long-term archiving on: : Thursday, March 24, 2011 - 2:03:52 PM
Identifiers
  • HAL Id : inria-00074054, version 1
Collections
Citation
Anshu Mehra, Ioannis Minis, Jean-Marie Proth. Hierarchical Production Planning for General Jobs Shops : Part 1 : Modeling. [Research Report] RR-2633, INRIA. 1995, pp.42. ⟨inria-00074054⟩
Share
Metrics
Record views
64
Files downloads
47
