The Euler Scheme for Lévy driven Stochastic Differential Equations - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1995
Denis Talay
  • Function : Author
  • PersonId : 833429
In relation with Monte-Carlo methods to solve some integro-differential equations, we study the approximation problem of $\ee g(X_T)$ by $\ee g(\bar X_T^n)$, where $(X_t,0\leq t\leq T)$ is the solution of a stochastic differential equation governed by a Lévy process $(Z_t)$, $(\bar X^n_t)$ is defined by the Euler discretization scheme with step $\fracTn$. With appropriate assumptions we show that the error $\ee g(X_T)-\ee g(\bar X_T^n)$ can be expanded in powers of $\frac1n$ if the Lévy measure of $Z$ has finite moments of order high enough. Otherwise the rate of convergence is slower and its speed depends on the behavior of the tails of the Lévy measure. The simulation of the increments of $(Z_t)$ is also discussed.
RR-2621.pdf (576.61 Ko) Télécharger le fichier
Dates and versions
inria-00074065 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00074065 , version 1
Cite
Philip Protter, Denis Talay. The Euler Scheme for Lévy driven Stochastic Differential Equations. [Research Report] RR-2621, INRIA. 1995, pp.31. ⟨inria-00074065⟩
82 View
106 Download
Share
