HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Logic Programming Environments: Dynamic Program Analysis and Debugging
Mireille Ducassé 1 Jacques Noyé 1
1 Lande - Logiciel : ANalyse et DEveloppement
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : Programming environments are essential for the acceptance of programming languages. This survey emphasizes that program analysis, both static and dynamic, is the central issue of programming environments. Because their clean semantics makes powerful analysis possible, logic programming languages have an indisputable asset in the long term. This survey is focused on logic program analysis and debugging. The large number of references provided show that the field, though maybe scattered, is active. A unifying framework is given which separates environment tools into extraction, analysis, and visualization. It facilitates the analysis of existing tools and should give some guide lines to develop new ones. Achievements in logic programming are listed; some techniques developed for other languages are pointed out, and some trends for further research are drawn. Among the main achievements are algorithmic debugging, tracing for sequential Prolog, and abstract interpretation. The main missing techniques are slicing, test case generation, and program mutation. The perspectives we see are integration, evaluation and, above all, automated static and dynamic analysis
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074067
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:25:21 PM
Last modification on : Friday, February 4, 2022 - 3:23:15 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:50:54 PM
Identifiers
  • HAL Id : inria-00074067, version 1
Citation
Mireille Ducassé, Jacques Noyé. Logic Programming Environments: Dynamic Program Analysis and Debugging. [Research Report] RR-2618, INRIA. 1995. ⟨inria-00074067⟩
Share
Metrics
Record views
123
Files downloads
475
