A Parametric Deformable Model to Fit Unstructured 3D Data - Archive ouverte HAL Access content directly
Reports Year : 1995
Laurent D. Cohen
Nicholas Ayache
  • Function : Author
  • PersonId : 833436
Recovery of unstructured 3D data with deformable models has been the subject of many studies over the last ten years. In particular, in medical image understanding, deformable models are useful to get a precise representation of anatomical structures. \  However, general deformable models involve large linear systems to solve when dealing with high resolution 3D images. The advantage of parametric deformable models like superquadrics is their small number of parameters to describe a shape combined with a better robustness in the presence of noise or sparse data. Also, at the expense of a reasonable number of additional parameters, free form deformations provide a much closer fit and a volumetric deformation field. \\ This article introduces such a model to fit unstructured 3D points with a parametric deformable surface based on a superquadric fit followed by a free form deformation to describe the cardiac left ventricle. We present the mathematical and algorithmic details of the method, as well as three experimental studies in a various number of 3D medical images. The extension of the method to track anatomical structures in spatio-temporal images (4D data) will be presented in a companion article \cite{BCA95d}
RR-2617.pdf (1.59 Mo) Télécharger le fichier
Dates and versions
inria-00074068 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00074068 , version 1
Cite
Eric Bardinet, Laurent D. Cohen, Nicholas Ayache. A Parametric Deformable Model to Fit Unstructured 3D Data. RR-2617, INRIA. 1995. ⟨inria-00074068⟩
262 View
370 Download
Share
