A Front-End Generator for Verification Tools
Abstract : This paper describes the Process Algebra Compiler (PAC), a front-end generator for process-algebra-based verification tools. Given descriptions of a process algebra's concrete and abstract syntax and semantics as structural operational rules, the PAC produces syntactic routines and functions for computing the semantics of programs in the algebra. Using this tool greatly simplifies the task of adapting verification tools to the analysis of systems described in different languages; it may therefore be used to achieve source-level compatibility between different verification tools. Although the initial verification tools targeted by the PAC are MAUTO and the Concurrency Workbench, the structure of the PAC caters for the support of other tools as well
Type de document :
Rapport
RR-2612, INRIA. 1995
Liste complète des métadonnées
https://hal.inria.fr/inria-00074073
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 14:26:26
Dernière modification le : jeudi 11 janvier 2018 - 16:32:50
Document(s) archivé(s) le : jeudi 24 mars 2011 - 14:08:32
Fichiers
  • HAL Id : inria-00074073, version 1
Collections
Citation
Rance Cleaveland, Eric Madelaine, Steve Sims. A Front-End Generator for Verification Tools. RR-2612, INRIA. 1995. 〈inria-00074073〉
Métriques
Consultations de la notice
153
Téléchargements de fichiers
168
