A Matrix-Free Preconditioner Applied to CFD
Rémi Choquet 1
1 ALADIN - Algorithms Adapted to Intensive Numerical Computing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : We consider the implicit time integration of the compressible Navier-Stokes equations. Each implicit step involves the solution of a costly non linear system. In this paper, we define a preconditioner to solve each linear system more cheaply within the framework of matrix-free algorithm. The main idea is to reuse the Krylov subspace across the time steps. We demonstrate some properties of the preconditioner and show the practical value of this approach for stiff problems which needs excessive small time steps with an explicit method.
Type de document :
Rapport
[Research Report] RR-2605, INRIA. 1995
Liste complète des métadonnées
https://hal.inria.fr/inria-00074080
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 14:27:15
Dernière modification le : jeudi 11 janvier 2018 - 06:20:08
Document(s) archivé(s) le : lundi 5 avril 2010 - 00:04:38
Fichiers
  • HAL Id : inria-00074080, version 1
Collections
Citation
Rémi Choquet. A Matrix-Free Preconditioner Applied to CFD. [Research Report] RR-2605, INRIA. 1995. 〈inria-00074080〉
Métriques
Consultations de la notice
138
Téléchargements de fichiers
500
