Performability Analysis for Degradable Computer Systems - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1995
Bruno Sericola
Degradable performance of fault-tolerant computer systems has given rise to considerable interest in mathematical models for combined evaluation of performance and reliability. Most of these models are based upon Markov processes. Several methods have been proposed for the computation of the probability distribution of performability upon an interval of time $[0,t]$. In this paper, we present a new algorithm based on the uniformization technique to compute this distribution for block degradable models. The main advantage of this method is its low polynomial computational complexity and its numerical stability. Moreover, it only deals with a non increasing sequence of positive numbers bounded by $1$. This important property allows us to determine new truncation steps which improve the execution time of the algorithm. We apply this method to a degradable computer system.
RR-2602.pdf (262.7 Ko) Télécharger le fichier
Dates and versions
inria-00074083 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00074083 , version 1
Cite
Hédi Nabli, Bruno Sericola. Performability Analysis for Degradable Computer Systems. [Research Report] RR-2602, INRIA. 1995. ⟨inria-00074083⟩
167 View
92 Download
Share
