Constrained Markov Decision Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1995
This report presents a unified approach for the study of constrained Markov decision processes with a countable state space and unbounded costs. We consider a single controller having several objectives; it is desirable to design a controller that minimize one of cost objective, subject to inequality constraints on other cost objectives. The objectives that we study are both the expected average cost, as well as the expected total cost (of which the discounted cost is a special case). We provide two frameworks: the case were costs are bounded below, as well as the contracting framework. We characterize the set of achievable expected occupation measures as well as performance vectors. This allows us to reduce the original control dynamic problem into an infinite Linear Programming. We present a Lagrangian approach that enables us to obtain sensitivity analysis. In particular, we obtain asymptotical results for the constrained control problem: convergence of both the value and the policies in the time horizon and in the discount factor. Finally, we present and several state truncation algorithms that enable to approximate the solution of the original control problem via finite linear programs.
Autre [cs.OH]
RR-2574.pdf (2.8 Mo) Télécharger le fichier
inria-00074109 , version 1 (24-05-2006)
  • HAL Id : inria-00074109 , version 1
Eitan Altman. Constrained Markov Decision Processes. RR-2574, INRIA. 1995. ⟨inria-00074109⟩
470 Consultations
510 Téléchargements
