Minimal Representation of Uniform Recurrence Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Computing Année : 2000
Alain Jean-Marie
Jean Mairesse
  • Fonction : Auteur
  • PersonId : 831681
We consider a system of uniform recurrence equations of dimension one. We show how the computation can be carried using minimal memory size with several synchronous processors. This result has applications in register minimization for digital circuitry and parallel simulation of timed marked graphs.
RR-2568.pdf (442.91 Ko) Télécharger le fichier
inria-00074113 , version 1 (24-05-2006)
inria-00074113 , version 2 (27-07-2007)
  • HAL Id : inria-00074113 , version 1
Bruno Gaujal, Alain Jean-Marie, Jean Mairesse. Minimal Representation of Uniform Recurrence Equations. SIAM Journal on Computing, 2000, 30 (5), pp.1701-1738. ⟨inria-00074113v1⟩
188 Consultations
381 Téléchargements
