The Pegasus heterogeneous multidatabase system, Computer, vol.24, issue.12, 1991. ,
DOI : 10.1109/2.116885
RETRIEVING AND INTEGRATING DATA FROM MULTIPLE INFORMATION SOURCES, International Journal of Cooperative Information Systems, vol.02, issue.02, 1993. ,
DOI : 10.1142/S0218215793000071
M(DM): an open framework for interoperation of multimodel multidatabase systems, [1992] Eighth International Conference on Data Engineering, 1992. ,
DOI : 10.1109/ICDE.1992.213189
The Data That You Won't Find In Databases: Tutorial panel on data exchange formats, Proc. ACM Sigmod, panel session, 1995. ,
Towards heterogeneous multimedia information systems: the Garlic approach, Proceedings RIDE-DOM'95. Fifth International Workshop on Research Issues in Data Engineering-Distributed Object Management, 1995. ,
DOI : 10.1109/RIDE.1995.378736
The Object Database Standard -ODMG 93, 1993. ,
A logic-based approach to query processing in federated databases, Information Sciences, vol.79, issue.1-2, 1993. ,
DOI : 10.1016/0020-0255(94)90037-X
Query Optimization in The Presence of Foreign Functions, Int. Conf. on VLDB, 1993. ,
Query optimization in heterogeneous DBMS, Int. Conf. on VLDB, 1992. ,
Rule-based Query Processing in the IDEA System, Int. Symp. on Advanced Database Technologies and Their Integration, 1994. ,
On resolving schematic heterogeneity in multidatabase systems, Distributed and Parallel Databases, 1993. ,
DOI : 10.1007/BF01263333
The Information Manifold, Distributed and Parallel Databases, 1993. ,
Language Features for Interoperability of Databases with Schematic Discrepancies, ACM SIGMOD Int. Conf, 1991. ,
On the logical foundations of schema integration and evolution in heterogeneous database systems, 1993. ,
DOI : 10.1007/3-540-57530-8_6
Data model and query evaluation in global information systems, Journal of Intelligent Information Systems, vol.16, issue.3?4, 1995. ,
DOI : 10.1007/BF00962627
Answering Queries Using Views, Proceedings of the ACM PODS Symposium, 1995. ,
The Use of Information Capacity in Schema Integration and Translation, Int. Conf. on VLDB, 1993. ,
Control of an extensible query optimizer: A planning-based approach, Int. Conf. on VLDB, 1993. ,
The Common Object Request Broker: Architecture and Specification, 1992. ,
Principles of Distributed Database Systems, 1991. ,
Query Transformation Techniques for Interoperable Query Processing in Cooperative Information Systems, Int. Conf. on Coop. Information Systems, 1994. ,
Federated database systems for managing distributed, heterogeneous, and autonomous databases, ACM Computing Surveys, vol.22, issue.3, 1990. ,
DOI : 10.1145/96602.96604
Principles of Database and Knowledge-Base Systems, 1988. ,
Technopôle de Nancy-Brabois, Campus scientifique, 615 rue du Jardin Botanique, pp.38031-38032 ,
78153 LE CHESNAY Cedex Unité de recherche INRIA Sophia-Antipolis, pp.78153-0249, 2004. ,
