HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Robot : Dynamic modeling system for robotics applications
Ammar Joukhadar 1
1 SHARP - Automatic Programming and Decisional Systems in Robotics
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes
Abstract : We describe models and algorithms designed to produce efficient and physically consistent dynamic simulations in the context of Intervention Robotics (i.e. for Robotics tasks involving strong physical interaction constraints and non necessarily rigid objects). These models and algorithms have been implemented within the $Robot\Phi$ system which can be potentially configured for a large variety of intervention-style tasks such as dextrous manipulations with a robot hand; manipulation of non-rigid objects; tele-programming the motions of an all-terrain vehicle; and some robot assisted surgery tasks (e.g. positioning of an artificial ligament in knee surgery). The approach uses a novel physically based modeling technique to produce dynamic simulations which are both efficient and consistent according to the laws of the Physics. The main advances over previous works in Robotics and Computer Graphics fields are twofold: the development of a unique framework for simultaneously processing motions, deformations, and physical interactions; and the incorporation of appropriate models and algorithms for obtaining efficient processing times while insuring consistent physical behaviors. These models are based upon three basic principles : the energy-based adaptative time step principle, the inertia-based adaptative discretization principle. and the dynamic surface/surface interactions law.
Document type :
Reports
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/inria-00074135
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:35:54 PM
Last modification on : Friday, February 4, 2022 - 3:21:39 AM
Long-term archiving on: : Monday, April 5, 2010 - 12:05:49 AM
Identifiers
  • HAL Id : inria-00074135, version 1
Collections
Citation
Ammar Joukhadar. Robot : Dynamic modeling system for robotics applications. RR-2543, INRIA. 1995. ⟨inria-00074135⟩
Share
Metrics
Record views
210
Files downloads
193
