Large Integrating formal verification methods of quantitative real-time properties into a development environment for robot controllers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1995
Muriel Jourdan
  • Fonction : Auteur
In this paper we describe our experience with a development environment for robot controllers, which provides the user with formal verification functionalities. We study how to augment these functionalities by also allowing formal verification of quantitative real-time properties. Our approach is based on the timed extension of a synchronous language, named Timed-Argos, and on a symbolic model-checking tool named Kronos for the real-time temporal logic TCTL. We illustrate this approach by a real example taken from the area of autonomous vehicles, which poses some challenges on the applicability of the theory and finally, we discuss some possible solutions. This {\em large-scale} real application is also an opportunity to identify new research directions in the area of formal verification.
Autre [cs.OH]
RR-2540.pdf (343.46 Ko) Télécharger le fichier
inria-00074138 , version 1 (24-05-2006)
  • HAL Id : inria-00074138 , version 1
Muriel Jourdan. Large Integrating formal verification methods of quantitative real-time properties into a development environment for robot controllers. RR-2540, INRIA. 1995. ⟨inria-00074138⟩
40 Consultations
101 Téléchargements
