Specifying and verifying a transformer station in Signal and SignalGTi
Hervé Marchand 1 Éric Rutten 1 Mazen Samaan 2
1 EP-ATR - Environnement de programmation d'applications temps réel
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : We present the specification and verification of the automatic circuit-breaking behavior of an electric po­wer transformer station using the synchronous ap­pro­ach to reactive real-time systems, and particularly the Signal language. The synchronous languages have a ma­thematical model supporting the various phases of the development of a control system: specification, verification, simulation, code generation, and implementation. Their semantics are at the base of the various tools dedicated to each phase and integrated into homogeneous design environments. The methodology associated with the data flow language Signal is demonstrated on the example of the functional description of a medium tension power transformer station and the specification of its automatic behavior upon the occurrence of an electrical default. The specification of the complex hierarchical, state-based and preemptive behavior is made in SignalGTi, an extension of Signal with the notions of time intervals and preemptive tasks. For the validation of the specification, a graphical simulator is generated using the execution environment for Signal. Properties required by the application are proved to hold on the specification of the controller, using the proof method associated with Signal.
Type de document :
Rapport
[Research Report] RR-2521, INRIA. 1995
Liste complète des métadonnées
https://hal.inria.fr/inria-00074157
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 14:38:31
Dernière modification le : vendredi 16 novembre 2018 - 01:28:18
Document(s) archivé(s) le : lundi 5 avril 2010 - 00:06:13
Fichiers
  • HAL Id : inria-00074157, version 1
Citation
Hervé Marchand, Éric Rutten, Mazen Samaan. Specifying and verifying a transformer station in Signal and SignalGTi. [Research Report] RR-2521, INRIA. 1995. 〈inria-00074157〉
Métriques
Consultations de la notice
337
Téléchargements de fichiers
109
