Bisimulation for higher-order process calculi - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1995
A higher-order process calculus is a calculus for communicating systems which contains higher-order constructs like communication of terms. We analyse the notion of bisimulation in these calculi. We argue that %, if static binding is assumed, both the standard definition of bisimulation (i.e., the one for CCS and related calculi), as well as higher-order bisimulation \cite{AsGi88,Bou89,Tho90} are in general unsatisfactory, because over-discriminating. We propose and study a new form of bisimulation for such calculi, called context bisimulation, which yields a more satisfactory discriminanting power. A drawback of context bisimulation is the heavy use of universal quantification in its definition. A major goal of the paper is to find characterisations which make bisimilarities easier to verify. An important role in our theory is played by the factorisation theorem: When comparing the behaviour of two processes, it allows us to «isolate» subcomponents which might cause differences, so that the analysis can be concentrated on them.
Autre [cs.OH]
RR-2508.pdf (353.16 Ko) Télécharger le fichier
inria-00074170 , version 1 (24-05-2006)
  • HAL Id : inria-00074170 , version 1
Davide Sangiorgi. Bisimulation for higher-order process calculi. RR-2508, INRIA. 1995. ⟨inria-00074170⟩
83 Consultations
217 Téléchargements
