Formal Verification of Concurrent programs: How to specify UNITY using the Larch Prover
Abstract : Prover to verify concurrent programs. The chosen specification environment is {\sc UNITY}, because it provides a higher level of abstraction to express solutions to parallel programming problems. We investigate how the syntax and the semantic of {\sc UNITY} can be mechanized in {\sc LP}, a theorem prover designed to check and reason about algebraic specifications, and how we can use the theorem proving methodology to prove safety and liveness.
Type de document :
Rapport
[Research Report] RR-2475, INRIA. 1995
Liste complète des métadonnées
https://hal.inria.fr/inria-00074199
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 14:44:12
Dernière modification le : samedi 17 septembre 2016 - 01:06:55
Document(s) archivé(s) le : lundi 5 avril 2010 - 00:06:39
Fichiers
  • HAL Id : inria-00074199, version 1
Collections
Citation
Boutheina Chetali. Formal Verification of Concurrent programs: How to specify UNITY using the Larch Prover. [Research Report] RR-2475, INRIA. 1995. 〈inria-00074199〉
Métriques
Consultations de la notice
183
Téléchargements de fichiers
128
