HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Efficient Incremental Garbage Collection for Workstation/Server Database Systems
Abstract : We describe an efficient server-based algorithm for garbage collecting object-oriented databases in a workstation/server environment. The algorithm is incremental and runs concurrently with client transactions, however, it does not hold any locks on data and does not require callbacks to clients. It is fault tolerant, but performs very little logging. The algorithm has been designed to be integrated into existing OODB systems, and therefore it works with standard implementation techniques such as two-phase locking and write-ahead-logging. In addition, it supports client-server performance optimizations such as client caching and flexible management of client buffers. We describe an implementation of the algorithm in the EXODUS storage manager and present results from an initial performance study of the implementation. These results demonstrate that the introduction of the garbage collector adds minimal overhead to client operations.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074266
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:54:04 PM
Last modification on : Thursday, February 3, 2022 - 11:18:45 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 4:21:25 PM
Identifiers
  • HAL Id : inria-00074266, version 1
Collections
Citation
Laurent Amsaleg, Olivier Gruber, Michael Franklin. Efficient Incremental Garbage Collection for Workstation/Server Database Systems. [Research Report] RR-2409, INRIA. 1994. ⟨inria-00074266⟩
Share
Metrics
Record views
92
Files downloads
92
