Abstract : We describe a general theoretical framework for algorithms that adaptively tune all their parameters during the restoration of a noisy image. The adaptation procedure is based on a mean field approach which is known as ``Deterministic Annealing'', and is reminiscent of the ``Deterministic Bolzmann Machiné'. The algorithm is less time consuming in comparison with its simulated annealing alternative. We apply the theory to several architectures and compare their performances.
