Larchant-RDOSS: a distributed shared persistent memory and its garbage collector
Marc Shapiro 1 Paulo Ferreira 1
1 SOR - Distributed Object Systems
Inria Paris-Rocquencourt
Abstract : Larchant-RDOSS is a distributed shared memory that persists on reliable storage across process lifetimes. Memory management is automatic: including consistent caching of data and of locks, collecting objects unreachable from the persistent root, writing reachable objects to disk, and reducing store fragmentation. Memory management is based on a novel garbage collection algorithm, that approximates a global trace by a series of local traces, with no induced I/O or locking traffic, and no synchronization between the collector and the application processes. This results in a simple programming model, and expected minimal added application latency. The algorithm is designed for the most unfavorable environment (uncontrolled programming language, reference by pointers, distributed system, non-coherent shared memory) and should work well also in more favorable settings.
Document type :
Reports
Complete list of metadatas
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00074276
Contributor : Rapport de Recherche Inria <>
Submitted on : Wednesday, May 24, 2006 - 2:54:54 PM
Last modification on : Friday, May 25, 2018 - 12:02:05 PM
Long-term archiving on: Tuesday, April 12, 2011 - 4:22:44 PM
Identifiers
  • HAL Id : inria-00074276, version 1
Collections
Citation
Marc Shapiro, Paulo Ferreira. Larchant-RDOSS: a distributed shared persistent memory and its garbage collector. [Research Report] RR-2399, INRIA. 1996. ⟨inria-00074276⟩
Share
Metrics
Record views
134
Files downloads
279
