New interface
Reports (Research report)
Lyapunov exponents of controlled SDE's and stabilizability property : Some examples
Fabien Campillo 1 Abdoulaye Traore 1
1 MEFISTO
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : We consider a stochastic differential equation with linear feedback control~: \begindisplaymath dX_t = (A+B\,K)\,X_t\, dt + \sum_k=1^r(A_k+B_k\,K)\,X_t\,\circ\! dW_k(t) \enddisplaymath where $K$ is the feedback gain matrix. For each value of $K$, let $\lambda_K$ be the Lyapunov exponent associated with the solution of the SDE. The set of $\lambda_K$, as $K$ describe the set of matrices, is a connected interval of $\R$. We present some examples where $-\infty$ is the lower bound of this set. For these cases, we say that the corresponding EDS is stabilizable.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00074278
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:55:49 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:12 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 4:24:08 PM
Identifiers
  • HAL Id : inria-00074278, version 1
Collections
Citation
Fabien Campillo, Abdoulaye Traore. Lyapunov exponents of controlled SDE's and stabilizability property : Some examples. [Research Report] RR-2397, INRIA. 1994. ⟨inria-00074278⟩
Share
Metrics
Record views
226
Files downloads
339
