An Implementation of Global Flush Primitives Using Counters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
We present an implementation of \gfp\ using counters. This implementation costs comparable to the most lightweight implementation of causal ordering. Thus, at a comparable cost, the presented implementation enriches functionality compared to causal ordering; as \gfp\ permit making an assertion about messages sent in the past of sending \im, in the future of sending \im, about both, or neither, where the past and the future of an event is defined using the relation ''happened before.'' Using \gfp, a message can be sent to any subset of processes specified as a parameter.
RR-2395.pdf (206.9 Ko) Télécharger le fichier
inria-00074280 , version 1 (24-05-2006)
  • HAL Id : inria-00074280 , version 1
M. Ahuja, Michel Raynal. An Implementation of Global Flush Primitives Using Counters. [Research Report] RR-2395, INRIA. 1994. ⟨inria-00074280⟩
85 Consultations
180 Téléchargements
