HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Applying the Synchronous Approach for Real Time Active Visual Reconstruction
Eric Marchand 1 Eric Rutten 2 François Chaumette 1
1 TEMIS - Advanced Image Sequence Processing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
2 EP-ATR - Environnement de programmation d'applications temps réel
Abstract : In this paper, we apply the synchronous approach to real time active visual reconstruction. It illustrates the adequateness of signal, a synchronous data flow programming language and environment, for the specification of a system dealing with various domains such as robot control, computer vision and programmation of hierarchical parallel automaton. More precisely, one application consists in the 3D structure estimation of a set of geometrical primitives using an active vision paradigm. At the level of camera motion control, the visual servoing approach (a closed loop with respect to vision data) is specified and implemented in \sc Signal as a function from sensor inputs to control outputs. Furthermore, the 3D reconstruction method is based on the ``structure from controlled motion'' approach (constraining camera motion for optimal estimation). Its specification is made in parallel to visual servoing, and involves the delay mechanism of \signal\ for the specification of filters. This reconstruction involves focusing on each object; we thus present a perception strategy for connecting up several estimations, using tasks hierarchies interruption and time intervals in \signal. The integration of these techniques is validated experimentally by their implementation on a robotic cell, from which we present experimental results.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074294
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:59:39 PM
Last modification on : Friday, February 4, 2022 - 3:18:48 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:32:16 PM
Identifiers
  • HAL Id : inria-00074294, version 1
Citation
Eric Marchand, Eric Rutten, François Chaumette. Applying the Synchronous Approach for Real Time Active Visual Reconstruction. [Research Report] RR-2383, INRIA. 1994. ⟨inria-00074294⟩
Share
Metrics
Record views
374
Files downloads
33
