HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Crest lines extraction in volume 3D medical images : a multi-scale approach
Abstract : Recently, we have shown that the differential properties of the surfaces represented by 3D volumic images can be recovered using their partial derivatives. For instance, the crest lines can be characterized by the first, second and third partial derivatives of the grey level function $I(x,y,z)$. In this paper, we show that~: - the computation of the partial derivatives of an image can be improved using recursive filters which approximate the Gaussian filter, - a multi-scale approach solves many of the instability problems arising from the computation of the partial derivatives, - we illustrate the previous point for the crest line extraction (a crest point is a zero-crossing of the derivative of the maximum curvature along the maximum curvature direction). We present experimental results of crest point extraction on synthetic and 3-D medical data.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074338
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:05:50 PM
Last modification on : Thursday, February 3, 2022 - 11:16:25 AM
Long-term archiving on: : Sunday, April 4, 2010 - 10:15:32 PM
Identifiers
  • HAL Id : inria-00074338, version 1
Collections
Citation
Olivier Monga, Richard Lengagne, Rachid Deriche. Crest lines extraction in volume 3D medical images : a multi-scale approach. [Research Report] RR-2338, INRIA. 1994. ⟨inria-00074338⟩
Share
Metrics
Record views
78
Files downloads
240
