HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
On the Expressive Power of Counting
Stéphane Grumbach 1 Christophe Tollu 2
1 VERSO - Databases
Inria Paris-Rocquencourt, CNRS - Centre National de la Recherche Scientifique : UMR8629
Abstract : We investigate the expressive power of various extensions of first-order, inductive, and infinitary logic with counting quantifiers. We consider in particular a LOGSPACE extension of first-order logic, and a PTIME extension of fixpoint logic with counters. Counting is a fundamental tool of algorithms. It is essential in the case of unordered structures. Our aim is to understand the expressive power gained with a limited counting ability. We consider two problems: (i) unnested counters, and (ii) counters with no free variables. We prove a hierarchy result based on the arity of the counters under the first restriction. The proof is based on a game technique that is introduced in the paper. We also establish results on the asymptotic probabilities of sentences with counters under the second restriction. In particular, we show that first-order logic with equality of the cardinalities of relations has a 0/1 law.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074344
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:06:19 PM
Last modification on : Friday, February 4, 2022 - 3:08:02 AM
Long-term archiving on: : Monday, April 5, 2010 - 12:08:38 AM
Identifiers
Citation
Stéphane Grumbach, Christophe Tollu. On the Expressive Power of Counting. [Research Report] RR-2330, INRIA. 1992, pp.38. ⟨inria-00074344⟩
Share
Metrics
Record views
188
Files downloads
130
